http://blog.stereophile.com/ssi2010/computer_audio_ssi/
In discussing USB cables, he said that the cheap generic cables can significantly limit sound quality. Yes, USB cables have a sound! There are three USB cables that Ayre recommends: Cardas, AudioQuest, and Transparent, none very expensive. For a computer dedicated to sound reproduction, Silberman recommends having 8GB or more memory (for those with 64-bit operating systems; a 32-bit OS will only handle up to 4GB of RAM). Less than 8GB will work, but won't sound as good. Perhaps most puzzling: the sound will be better if instead of a conventional spinning hard drive the computer is equipped with solid-state memory to store the operating system. This is in spite of the fact that the music computer files themselves are stored on an external hard drive of the conventional sort.
WTF
