SPENDOR A6R זכו כרמקולי הסטריאו הטובים ביותר לשנת 2015 במגזין האנגלי ?WHAT HI FI שנה שנייה ברציפות!
soundquest
Spendor A6R scoops this major award. "An outstanding pair of speakers that deliver detail and dynamic punch. Audition them, and you'll hear where every penny of your money is going
"They put in a superb performance across the frequency range, showcasing a surprisingly deep and punchy low end alongside an expressive midrange and a detailed, refined treble. Each feels like a well-judged part of a whole, slotting together perfectly to produce a well-balanced, coherent system."
"Detail is second to none too, and there is layer upon layer of subtlety and fine detail to grasp onto. Notes have depth and dimension, nuances are picked up in all their glory and vocals are conveyed with all the reality and emotion with which they were recorded."
Test Verdict - "An outstanding pair of speakers..."
Group Test Verdict - Winner
לינק לביקורת
בנוסף:
Hi-Fi Choice magazineFebruary 2014
"Bass is excellent and I can vouch that Spendor’s special port design works very well. Even at high levels, there is no huffing, puffing or chuffing, and the low frequencies remain tight and supple."
"The midrange performance of the A6R is lovely. It does that very special trick of being incisive and detailed without sounding like a speaker that’s trying to be incisive and detailed! Rather it has a smooth, gentle, delicate sort of character that seems to dissolve away and let you focus on the mix; there’s no honking or squawking from the cone, no sense that you’re listening to something artificial."
Its sheer competence across the board means it’s really hard, if not impossible, to beat. You just can’t help really liking it, no matter what you’re currently used to and how expensive it is. As such, it comes heartily recommended."
לינק לביקורת
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות
ירמיהו 43 תל אביב > 03-6721808
www.soundquest.co.il
סאונדקווסט בפייסבוק
    KB 121 · צפיות: 412
    KB 14.4 · צפיות: 456
    KB 27.7 · צפיות: 454
    KB 31.3 · צפיות: 443
    KB 121 · צפיות: 324
    KB 30.1 · צפיות: 446
    KB 44.1 · צפיות: 296
    KB 18.5 · צפיות: 457
