yaniv.L
sonus faber sonetto iii
TECHNICAL SPECIFICATIONS
SYSTEM
3-way floorstanding loudspeaker system. Vented box design.
LOUDSPEAKERS
Tw: High Definition DAD™ driver. DKM dome diaphragm, Ø 29mm
Md: Custom diaphragm made with cellulose pulp and other natural fibers, Ø 150mm
W: Ultra-free compression basket, aluminum cone for maximum speed. Ø 2x150mm cone drivers.
CROSSOVER
220Hz – 3.250Hz
FREQUENCY RESPONSE
42 Hz – 25.000 Hz
SENSITIVITY
89 dB SPL (2.83 V/1m)
NOMINAL IMPEDANCE
4 ohm
SUGGESTED AMPLIFIER POWER OUTPUT
50W – 250W, without clipping
DIMENSIONS (HXWXD)
1018 x 219 x 305 mm
40 x 9 x 12 in
WEIGHT
16 Kg ea – net weight
35,2 Ib ea – net weight
אפשרות טריד אין /תשלומים
מחיר רגיל 18900
ימכר במחירהזדמנות בנייד
לוינסון
0507628600
SYSTEM
LOUDSPEAKERS
CROSSOVER
220Hz – 3.250Hz
FREQUENCY RESPONSE
42 Hz – 25.000 Hz
SENSITIVITY
NOMINAL IMPEDANCE
4 ohm
DIMENSIONS (HXWXD)
1018 x 219 x 305 mm
40 x 9 x 12 in
WEIGHT
מחיר רגיל 18900
לוינסון
0507628600
