מחיר 3,650 ש"ח
052-9177009 (דרך יד 2)
Specifications
Continuous Power Output 70 watts/ch
( Dist. 20-20 kHz, < 0.03%, 8 ohms)
Total Harmonic Distortion (20Hz-20kHz) < 0.03% at rated power, 1/2 power or 1 watt
Intermodulation Distortion (60 Hz : 7 kHz, 4:1) < 0.03% at rated power, 1/2 power
or 1 watt
Frequency Response
Phono Input 20Hz-15kHz, ±0.3dB
Line Level Inputs 10Hz-100kHz, +1, –3dB
Damping Factor (20-20,000 Hz, 8 ohms) 180
Input Sensitivity / Impedance
Phono Input 2.5mV / 47 kOhms
Line Level Inputs 150 mV / 24 kOhms
Input Overload
Phono Input 180mV
Line Level Inputs 5V
Premp Output / Impedance 1V / 470 Ohms
Tone Controls - Bass / Treble ±6 dB at 100Hz / 10kHz
(Signal to Noise Ratio (IHF “A” weighted
Phono Input 80 dB
Line Level Inputs 100 dB
Power Consumption 300 W, 36 W - Idle, 3.7 W - Standby
Dimensions (W x H x D) 437 x 92 x 342 mm
Specifications
or 1 watt
Frequency Response
Input Overload
Phono Input 180mV
Phono Input 80 dB
