HEGEL HD30 זכה ב- DAC השנה 2016 במגזין AUDIO VIDEO
soundquest
Masterpiece
HEGEL HD30 סטרימר ממיר DSD זכה בממיר השנה ובפרס היוקרתי RED Fingerprint במגזין High Fidelity
הסטרימר ממיר רפרנס החדש מבית HEGEL
הממיר כולל שני שנאים נפרדים (לאנלוג ולדיגיטל)
שעון מבית קריסטל אשר עבר שדרוג ע"י מהנדסי HEGEL.
הממיר כולל סטרימר ו AirPLAY
The HD30 is the ultimate digital control center. It does everything you can dream of, and does so with world-class quality. There is an abundance of inputs, ranging from balanced AES/EBU and BNC connectors, to Network and USB connections - with the latter also accepting DSD signals. The built-in volume attenuator allows you to connect directly to a power amplifier or a pair of active loudspeakers. Highly advanced power supplies and careful lay-out brings the noise floor down towards a mindblowing -150dB. In short... Do you even dare to try it?
When designing a digital-to-analog converter of world class, you are essentially making a masterpiece. One for others to try and copy. It is not enough to select the best components on the market and lay them out cleverly. When creating a masterpiece, you must question if you can make it better than the best. The HD30 was just such a masterpiece project. To reach goals that, up until now, was seen as unobtainable, we need to tweak the world’s best measuring equipment available. Just to be able to fine-tune our clock crystals and power supplies. We designed master clocks from the ground up and went to great lengths to design ultra low noise power supplies and shielding from outside interference. The results are stunning. The musicality of the HD30 is at a level never before heard. You can experience instruments and virtually feel the room they play in. You feel the smile widening in your face and the hair rising on your arms when the HD30 begins to play. The finger touching the string, a millisecond before the guitar starts to sound. The singer drawing that breath of anticipation right before he starts playing in front of a live crowd.
Whether you choose to use Apple AirPlay, a CD-player, a computer or any other device. The HD30 will bring all the music and enthusiasm that exists in the recording.
קבצים מצורפים:
file.php
file.php
file.php
file.php
10314020_1177446042280712_1827337182145765099_n-jpg.27095
201601_poty_b-png.27096
12778882_1177445928947390_6581013659356691947_o-jpg.27094
12718134_1177443872280929_3772326594384581998_n-png.27093
file.php
file.php
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות
ירמיהו 43 תל אביב > 03-6721808
www.soundquest.co.il
סאונדקווסט בפייסבוק
נערך לאחרונה על ידי soundquest בתאריך היום 16:11, נערך 5 פעמים בסך הכל.
    KB 77.7 · צפיות: 571
    KB 60.6 · צפיות: 613
    KB 36 · צפיות: 595
    KB 90.7 · צפיות: 638
