Classe Audio CP-500 high-end stereo preamplifier
HiFiBuzz
קדם מגבר סטריאו איכותי ביותר של CLASSE .
The Classé CP-500 is an example of our attention to detail and superior performance. This preamplifier is built completely symmetrical. The touchscreen concept allows easy and comfortable all the important settings on the device (eg, adjusting the volume and characteristics of personal preference, free naming of the inputs). Many more features will then be possible by the microprocessor control, without affecting the sensitive pathway in its quality. On the rear panel are RS-232 and IR ports.
THD: 0.003%
Frequency Response: 20 Hz - 200 kHz +0 /-0.1dB
Crosstalk: Better than -120 dB (1 kHz)
Channel separation:> 100dB
Signal / noise ratio: 100dB
Voltage: 240v
Power consumption: 30W
5 High-level inputs, one XLR (balanced) and a tape loop
Balance and level of each source individually adaptable
Trigger connections for the power amplifiers
easy to use via touch screen or remote control
Dimensions (W x H x D): 445 x 121 x 419 mm
Weight: 12 kg
מחיר הזדמנות
15,400 ש"ח
יואב
050-5296022
    KB 40.6 · צפיות: 399
