Audiofreak
ממיר מעולה, נדיר בלוחות
מחיר 4000 ש"ח
, Stereophile Recommended:
"The Bryston BDA-1 let me enjoy the best-sounding digital playback I've ever heard in my listening room"
נתונים טכניים:
Digital-to-analog converter with remote control of digital input and volume.
Digital inputs: USB 1.1, four S/PDIF electrical (RCA, BNC);
two S/PDIF optical (TosLink), AES/EBU (XLR). Digital input sample rates accepted: 32, 44.1, 48, 88.2, 96, 176.4, and 192kHz (transformer-coupled S/PDIF, AES/EBU);
32–48kHz, USB. Input word lengths accepted: 16–24-bit, S/PDIF and AES/EBU;
16-bit, USB. Digital output: S/PDIF bypass loop output via RCA jacks.
Control inputs: RS-232 port via 9-pin subminiature connector; remote 12V power-on/off trigger. Analog outputs: 1 pair each RCA, balanced XLR. Maximum output level: 2.3V RMS unbalanced, 4.6V balanced. Output impedance: 100 ohms balanced, 50 ohms unbalanced. Frequency response: 20Hz–20kHz, ±0.1dB. THD+noise at 1kHz: 0.002%. IMD (CCIF): 0.0003%, 19+20kHz. Channel separation: 109dB at 1kHz. Output noise: <4ÊV or –100dB, 20Hz–20kHz (ref. 1V). Signal/noise: 140dB. Dynamic range at –60dBFS: 123dB. Jitter: <250ps peak–peak. Power consumption: 10VA.
מחיר 4000 ש"ח
נתונים טכניים:
