Audio Physic SCORPIO 2
  • פותח הנושא Av1
Av1
תוצרת גרמניה, חדשים באריזות!
יש 2 גימורים מהדגם הזה: מייפל ושרי
קישור לאתר לגבי הגימורים:
http://www.audiophysic.com/furniere/index.html
Introduced in 2005, the Scorpio sets a new standard for loudspeakers in this price range. Competing with far more expensive products, the Scorpio offers tremendous value for the price. It’s all here, the unbelievable soundstage, refinement, natural timbre and tight and tuneful bottom end.
Four seven-inch high performance side firing woofers produce powerful bass without overhang or boom.
"This added up to a loudspeaker so excellent that even at the end of my time with the Scorpios I still found myself constantly mistaking stereo sounds for real sounds. Add in a truly elegant shape and superb cabinetry, and you have a loudspeaker that sets a new, higher standard for the price range. If you are anywhere this price range, you need to go hear these. And even if you are planning on spending considerably more, especially if you have a medium to medium large room, go hear them too as the Scorpios are not just great for the money, they are just plain great". Todd Warnke, Enjoy the Music, Superior Audio
Sophisticated computer aided design was utilized to create the elegant and sophisticated enclosure
Proprietary Hyper-Holographic Midrange Drivers (2)
Proprietary VCT (Vibration Control Terminals) use elastomeric suspension to isolate vibration transfer between speaker and cables
Ultra high quality Rhodium plated WBT binding posts.
7 degree cabinet angle equalizes phase differences between the tweeter and midrange for correct alignment, producing outstanding dimensionality
Internal wiring by Wireworld
Extensively internal bracing for and incredibly rigid and non-resonant enclosure
Four 7” metal cone high performance woofers for fast, articulate bass
Two different midrange drivers are optimized for their individual operating range
Metal outrigger supports for outstanding coupling and stability while allowing for easy adjustment from the top
43"H x 8"W x 15.4"D
30Hz - 33kHz
91dB Sensitivity
4 Ohm
$8495 in Natural Cherry, Light Maple, Dark Maple or Black Ash. $8995 in Rosenut or Macassar Ebony.​
המוצר באתר החברה:
http://www.audiophysic.de/scorpio/index_e.html
ביקורות:
http://www.stereophile.com/floorloudspeakers/506ap/index.html
http://www.enjoythemusic.com/superioraudio/equipment/0406/audio_physic_scorpio.htm
http://community.whathifi.com/forums/p/332803/332815.aspx
מחיר חו"ל נכון להיום 8.500 $ * לא כולל מיסים מקומיים בערך של 8-10% מהמחיר
ימכרו במחיר הזדמנות שאיני יכול לפרסם
אין הדגמה הרמקולים סגורים באריזתם המקורית = חדשים לחלוטין!
יש אחריות
SOUNDHOLIC
מוצרי סטריאו וקולנוע ביתי אולטימטיביים, בהזדמנויות.
* הצעות קניה ומכירה מתקבלות ללא תשלום
shimimor@017.net.il
052-3153-707
מור יוסף שמעון
