Accuphase power amp. P 370
HiFiBuzz
למכירה במצב חדש .מגבר הספק של חברת אקיופייז (כל מי שמכיר יודע על איזה איכות מדובר)
בעל צליל נקי ומושלם.
המגבר במצב מצויין. התקבל מעיסקת טרייד אין. בן 8 שנים .
מפרט טכני:
Continuous Average Output (20 to 20,000 Hz) Stereo mode 400 watts per channel into 1 ohms★ (both channels driven) 300 watts per channel into 2 ohms 150 watts per channel into 4 ohms 75 watts per channel into 8 ohms Note: Ratings marked ★ are for music signals only. Monophonic mode 800 watts into 2 ohms★ (bridge connection) 600 watts into 4 ohms 300 watts into 8 ohms Note: Ratings marked ★ are for music signals only. m Total Harmonic Distortion Stereo mode (both channels driven) 0.05% with 2-ohm load 0.02% with 4- to 16-ohm load Monophonic operation (bridged connection) 0.02% with 4- to 16-ohm load m Intermodulation Distortion 0.003% m Frequency Response At rated output: 20 - 20,000 Hz +0, –0.2 dB At 1 watt output: 0.5 - 160,000 Hz +0, –3.0 dB m Gain 28.0 dB (in stereo and monophonic operation) m Output Load Impedance Stereo operation: 2 to 16 ohms Monophonic operation: 4 to 16 ohms ★ With music signals, load impedance of 1 ohm (stereo) or 2 ohms (mono) can be driven. m Damping Factor 200 (stereo/monophonic operation) m Input Sensitivity Stereo mode 0.98 V for rated output (with an 8-ohm load) 0.11 V for 1 watt output Monophonic mode 1.95 V for rated output 0.11 V for 1 watt output m Input Impedance Balanced: 40 kilohms Unbalanced: 20 kilohms m Signal-to-Noise Ratio 120 dB (rated continuous average output) (A-weighted, input shorted) m Output Level Meters –50 dB to +3 dB, logarithmic scale, OFF switch provided m Power Requirements 120V/230V (Voltage as indicated on rear panel) AC, 50/60Hz m Power Consumption 44 watts idle 475 watts in accordance with IEC-65 335 watts at rated power output into 8 ohms m Maximum Dimensions Width: 475 mm (18-11/16") Height: 180 mm (7-1/16") Depth: 417 mm (16-7/16") m Weight 24.4 kg (53.8 lbs) net Remarks 29.0 kg (63.9 lbs) in shipping carton
אבקש לא לפנות בהצעות לא רציניות.
המחיר 11,500 ש"ח
050-5296022 יואב
up
    KB 30.3 · צפיות: 745
    KB 34.7 · צפיות: 728
    KB 35.7 · צפיות: 724
    KB 26.7 · צפיות: 723
