האם המפרט של LCD נראה טוב לעבודה בישראל?
Product
Click to enlarge Vizio 47-inch LCD SV470XVT1A 120Hz HDTV
[SV470XVT1A-B]
Tell a Friend Item Price: $749.95Free Shipping
Item Description
Vizio 'XVT' was designed from the ground up to set a new standard of Full High Definition technology. Starting with the remarkable refresh rate of 120Hz, the Vizio SV470XVT FHDTV adds Full High Definition 1080p, 4x HDMI inputs, SRS TruSurround XT sound and Smooth Motion picture technology to deliver impeccable results. Add more than 2-Million pixels and dynamic 6,500:1 contrast ratio, your new VIZIO SV470XVT is the newest caliber of technology in the Full High Definition Television space.
120Hz, Full HD 1920 x 1080 native Resolution LCD - 120Hz refresh rate coupled with 1920x1080 resolution provides only the smoothest-motion imagery. Enjoy DVD movies, gaming, or High Definition television with astounding clarity. Add 1080p processing power for Full High Definition viewing and the Vizio SV470XVT is the new home theatre solution!
Elegant Design - The SV470XVT incorporates an all new chassis design with elegant slim piano-black bezel construction and brushed silver accents.
SRS TruSurroundXT - Three built-in speakers provide the ultimate home theatre sound solution that will truly set it apart from the competition.
178 Degree Viewing Angle - Invite family and friends to watch movies and sporting events. Every seat is a great seat.
- High Resolution 1920 X 1080 Pixels Wide Screen 16X9
- Ideal in Bright Light Environments - Minimal Glare
- Digital HDTV & Standard TV Comination Tuner
- Free HDMI Cable
- Full HD Formats Supported (1080p, 1080i, 720p, 480p, 480i
- Computer Monitor (RGB) Up To 1920x1080 WXGA
- Wall Mounting Capable
- Typical Lamp Life of 50,000 Hours, Equivalent to 22 Years*
[*]Condition: Factory Recertified
[*]Warranty: 90-Day Manufacturer Warranty
Need a mount? Check out the mount link on the side of each page to see our full line of mounting solutions! K2 mounts are Vizio Recommended!"
Specifications
*Viewable: 46.96-in
Tuner: Integrated NTSC/ATSC/QAM HDTV Tuner
Supported TV Formats
1080p, 1080i, 720p, 720i, 480p, 480i
Native Panel Resolution: 1920 x 1080
Supported PC Resolutions
1920 x 1080, 1366 x 768, 1280 x 720, 1024 x 768, 854 x 480, 800 x 600
Specifications
Panel Type: 47" Diagonal*, 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.5415mm (H) x 0.5415mm (V)
Display Compatibility: FULL HDTV (1080P)
Signal Compatibility: 480i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV), 1080P (FULL HDTV)
Response Time: 5 ms (typical)
Colors: 1.06 Billions
Brightness: 500 cd/m2 (typical)
Contrast Ratio: 1300:1 / 6500:1 (w/DCR)
Viewable Angle: >178 degrees (horizontal and vertical)
Inputs
RF (F Connector for internal tuner): 1
HDMI with HDCP: 4
Analog Stereo Audio for HDMI Inputs: 1
Component YPbPr plus Stereo Audio: 2
Composite Video: 2
S-Video plus Stereo Audio: 1
Computer RGB plus Stereo Audio: 1
Service Port: 1
Outputs
Analog Audio out (RCA): 1
5.1 SPDIF Digital Optical Audio: 1
Headphone (Stereo Mini-Jack): 0
Additional Information
Picture-in-Picture (PIP)
Picture-outside-Picture (POP)
Closed Caption (CC)
V-Chip
3D Comb Filter
Zoom
Freeze
3:2 or 2:2 Reverse Pull-down
ATSC with 8VSB & QAM demodulation
ATSC with MPEG-2 decoding
NTSC Video decoding via RF: Yes, thru Antenna, Cable, or Satellite
NTSC Video decoding via Video: Yes, thru CVBS, S-Video, or Component
Progressive Scan Video: Yes, thru Component YPbPr, VGA or HDMI
HDTV: Yes, thru HDMI or Component YPbPr
Computer:640x480, 800x600, 1024x768 , 1280x1024, 1920x1080 via RGB or 1920x1080 via HDMI
Sound enhancement: Yes, SRS TrueSrround XT
Color Temperature: 6500K (standard), 5400K and 9300K
Color Fine Tuning: Independent Red, Green and Blue
Audio: Built-in 10W X 3
Lamp (LCD) / Panel (PDP) Life: 50000 hours
Power: IEC Connector for direct power line connection
Voltage Range100 ~ 240 Vac at 50/60 Hz
Power Consumption: 400W average
Removable Base
Weight
Gross:77.8 lbs
Net: 62.4 lbs
Without Stand: 56.9 lbs
Dimensions
Net: 43.9" W x 29.7" H x 10" D
Without Stand: 43.9" W x 28.1" H x 4" D
