פרס Grand Prix 2024 לראש MC החדש של TechDAS
קודו אודיו
New phono cartridge TDC01 Dia with Tapered Pipe Diamond Cantilever
The award winning was just announced in the Grand Prix 2024
The new TechDAS cartridge is formidable that its cantilever is made of"
"diamond machined in a tapered and tubular structure
Dia cartridge realizes an unrivaled resolution that no other cartridge"
"could achieve
It delivers such reality that it would be a true you-are-there"
experience, and you would feel as if this is actually happening in front
of you. At the same time, the sound is so natural as it has nothing
artificially emphasized. Probably this is because of its hollow tubular
"structure, which allows not only rigidity but also a superb flexible
https://techdas.jp/2024/04/11/new-phono-cartridge-tdc01-dia-with-tapered-pipe-diamond-cantilever/
