or-audio
סקירה חדשה למגבר
Moonriver 404 Reference
https://6moons.com/audioreview_articles/moonriver/?fbcl ... VQVsL0AN_M
https://moonriveraudio.com/the-404-reference-integrated-amplifier/
https://www.or-audio.co.il/moonriver-audio
Specifications
Inputs: 5 (line 1 and 4 optionally occupied by phono stage and USB DAC respectively, 1 x tape loop)
Outputs: 2 x preamp out, 1 x rec out
Max output power: 50 W / channel into 8 Ω
Frequency response: 10 Hz to 50 kHz
Total harmonic distortion: 0.05%
Signal to noise ratio: 85 dB (line)
Idle Consumption: 22 Watts
Dimensions (mm): 430 W x 390 D x 135 H
Weight: 13 kg
Weight: 13 kg
http://www.or-audio.co.il
052-8833339
Verity Audio * Ichos * Cocktail Audio * Rockna * hORNS * Triode Corp
Synthesis * Viard * AVID * Trafomatic * Audiobyte * Moonriver * Audio Hungary
