Amirbrand
לפרטים:
אמיר 050-3040200
UPnP-enabled to stream audio files from any hard disk server, such as HDX or UnitiServe, network attached storage (NAS) or laptop/computer via the home network
vTuner 5* full service Internet radio
Front-panel USB port for replay of MP3 player/iPod and USB-stored audio
Apple authenticated enabling digital output from iPod/iPhone for ultimate quality control, charging and front-panel content display when connected to front-panel USB port via standard Apple digital connector
Three 32bit/192kHz-capable S/PDIF inputs for external digital sources
Multiple intuitive control interfaces: Front panel, remote control handset and iPhone / iPod Touch app
Internal architecture for hi-res audio playback up to 32bit/192kHz over the network
Ethernet network connectivity for reliability. Wireless also available for convenience.
Streams/plays WAV, FLAC, AIFF, AAC, Windows Media-formatted content, ALAC, Ogg Vorbis and MP3 files from any suitable UPnP device or USB-connected storage device
Full Naim Multiroom functionality including Party Mode
Gapless playback available on all lossless file formats
Digital output on 75Ohm BNC connector
Switchable DIN/RCA Analogue outputs
Wired remote in
Wired remote out for preamplifier volume control
Performance upgradeable with addition of external XPS or 555 PS power supply or external DAC digital to analogue converter
RS232 for software upgrades
SHARC DSP and buffering with fixed sampling rates
Naim proprietary 16 times oversampling and digital filtering
Optical isolation of all key elements
Linear power supply with 200VA toroidal transformer with four separate windings for digital, DPS, audio clock and analogue sections
Seven pole analogue output filtering
Optical isolation of data control lines
Ultra low noise triple-regulated power supplies
Ground selector switch for optimum performance
High quality Burr Brown PCM1791A DAC
Naim reference non-magnetic, low-resonance low microphony case
OLED display for high contrast and easy visibility
British design and build
Specification
AUDIO INPUTS
Sample Rates Supported S/PDIF up to 192kHz
USB Inputs Front panel socket
UPnP Hi-Res UPnP playback up to 24bit/192kHz (WAV and FLAC)
Other Inputs Ethernet
AUDIO OUTPUTS
Analogue Outputs DIN and RCA
Line Outputs Fixed (level) 2.1V rms at 1kHz
Output Impedance 10Ω max.
Load Impedance 10kΩ min.
Frequency Response 10Hz – 20kHz, +0.1/-0.5dB
THD + N <0.1%, 10Hz -18kHz at full level
Phase Response Linear phase, absolute phase correct
Digital Outputs (type) S/PDIF, 75Ω BNC
Line Outputs Fixed (level) 2.2V rms
UPGRADES
Power Supply XP5 XS, XPS, 555 PS
Other DAC digital to analogue converter, Hi-Line, Power-Line
CONNECTIVITY
Remote Control Infra Red (RC5)
Remote Input 1 x rear panel 3.5mm jack (RC5 modulated/unmodulated)
Remote Output 2 x rear panel 3.5mm jack (RC5 modulated/unmodulated)
RS232 DE9 female (For software upgrade only)
Ethernet Cat5, WiFi
USB 1 x front panel
FORMATS
Audio Formats Supported Internet radio (Windows Media-formatted content, MP3 streams, MMS), Playlists (M3U, PLS), MP3, AAC (up to 320kbit/s, CBR/VBR) Apple Lossless (from iPod), Windows Media-formatted content-9 (up to 320kbit/s), WAV and FLAC (up to 32bit/96kHz via UPnP or USB
Multiroom Master: Will stream native quality WAV, FLAC and AIFF (up to 24bit/48kHz), ALAC (up to 16bit/44.1kHz), AAC and MP4 (up to 16bit/48kHz) files only Client: Will play 320kbps MP3 quality only
USER CONTROL INTERFACES
Front Panel Nine button matrix
Handheld Remote handset included; optional n-Stream User app for iPhone, iPod Touch and iPad available to download from the iTunes App Store
POWER
Mains Supply 100V, 115V, 230V; 50 or 60Hz
Power Supply Options Internal Integrated or External
Power Consumption 60VA max.
PRODUCT CERTIFICATIONS & LICENSES
Certifications Apple (Made for iPod), vTuner Premium
Licenses MP3, AAC, DAB
PHYSICAL
Dimensions 87 x 432 x 314mm (H x W x D)
Weight 10kg
אמיר 050-3040200
Wired remote in
Specification
AUDIO INPUTS
AUDIO OUTPUTS
UPGRADES
CONNECTIVITY
Ethernet Cat5, WiFi
USB 1 x front panel
FORMATS
POWER
PHYSICAL
Weight 10kg
