or-audio
מטרייד - סט AURIS AUDIO מגבר כוח + פרה/מגבר אוזניות//דק DSD
במחיר שאסור לפספס.....
מגבר כוח דגם DC250
hybrid מנורות/CLASS D
פרה/מגבר אוזניות/דק DSD דגם DHP-2
DC250
DHP-2
www.or-audio.co.il
0528833339
Facebook
מגבר כוח דגם DC250
DC250
The Auris DC-250 power amplifier is a class-D model, capable of delivering up to 2 x 250 Watts at 4 Ohms
It has an electronic tube on input in order to render its rendition more musically natural, it proves the best choice for Class-D and 21st century music. This power amp uses state-of-the-art D-Class circuitry, switch mode power supply and high-performance circuitry. This technology gives the amp Auris DC-250 the ability to power a wide range of speakers even of low impedance, with great rigor
Technical Specifications
Nominal power 1 % THD + N, SE Mode, 4Ω, 1 kHz 2 x 250 W
Nominal power 1 % THD + N, SE Mode, 8Ω, 1 kHz 2 x 125 W
Bandwith 8 Ω, -3 dB point, SE Mode 130 kHz
Frequency response 20 Hz - 20 kHz, 2 Ω - 8 Ω load range +/- 0.5 dB
Damping factor 8 Ω, 100 Hz > 500
THD + N 1 kHz, 1 W 0.008 %
Dynamic range A - weighted, SE Mode 112 dB
Dynamic range A - weighted, BTL Mode 121 dB
Finishing materials Genuine leather and walnut wood
Dimensions (WxDxH) mm 450 x 400 x 160
Weight (kg) 8
Weight (kg) 8
DHP-2
Digital to analog converter with implemented preamp option and headphone amplifier make this product
usable for wide range of systems
Based on the D1D, upgraded with preamp or direct mode and the best solid state headphone amplifier will allow you to use it in many systems
Easy to use and uniquely designed with remote control from solid aluminium
Input 1 x USB, 3 x Coax (RCA), 3 x TosLink
Output RCA
Output mode (Analog) Preamp or Direct Out
Headphone amp (Analog) TPA6120A2
Conversion rate USB: DSD64, DSD128, PCM max 32bit/384kHz; Coax (RCA): max 24bit/192kHz; TosLink: max 24bit/192kHz
Bluetooth 4.0
Weight (kg) 6,65
Output RCA
Bluetooth 4.0
Weight (kg) 6,65
www.or-audio.co.il
0528833339
