Salton Elad
Hello everyone, I'm Salton Elad.
I recently purchased the Biqu B1 SE Plus 3D printer from https://dfus3d.com/ , and after using it for a while, I wanted to share my experience—including the pros and cons.
The good things:
Large Build Volume: Great for larger projects or printing multiple items at once. Easy installation: The assembly process is simple, even for beginners. High print quality: the prints come out detailed and clean, which makes the printer ideal for both small and large models. Quiet operation: the printer works quietly, which is suitable for home use. User-friendly touchscreen: The touchscreen interface is responsive and easy to navigate.
The worst things:
Balancing the bed takes practice: even with balance aids, you may need a few tries to get a perfect result. Software bugs: There were small bugs at first, but the software update solved most of the problems. First layer adhesion problems: occasionally the first layer doesn't stick well, but adjusting the settings usually solves the problem. Final Verdict: Overall, the Biqu B1 SE Plus is an excellent 3D printer, especially for the price. It is user friendly, provides high quality prints and offers a large build space. However, you may need to make minor adjustments, such as balancing the bed and updating the software, to achieve optimal performance.
If you are interested, you can find more details here: https://dfus3d.com/shop/3d-printers/fdm-printers/%d7%9e%d7%93%d7%a4%d7%a1%d7%aa-biqu -b1-se-plus/.
The good things:
The worst things:
