Amirbrand
לפרטים:
אמיר
050-3040200
100 watts x 2 channels into 8 ohms
total harmonic distortion: 0.005% (at 20Hz to 20,000Hz)
frequency response: 10 -100,000 Hz (+0, -3dB)
signal-to-noise ratio: 95dB (line level), 82dB (phono), 110dB (power amp)
damping factor: greater than 200
built-in McIntosh Digital Engine up-sampling DAC for digital audio sources
built-in headphone amplifier
large power transformer with multiple filter capacitors and regulated power supply ensures stable noise free operation
patented McIntosh Power Guard circuit prevents amplifier clipping to protect speakers
Sentry Monitor and Thermal Protection circuits provide long amplifier operating life and protection against overheating
Home Theater Pass Through allows amplifier to become part of a multichannel sound system
fiber optic illuminated glass front panel for a beautiful appearance and long-term durability
illuminated power meters (with illumination on/off settings)
adjustable front-panel display brightness settings
Inputs:
USB (Type B) input for connection to a computer
supported bit depth and sample rates: up to 32-bit/192kHz
dedicated McIntosh USB audio driver required for playback on a Windows® PC (free USB driver download available from McIntosh Laboratory's website)
1 optical and 1 coaxial digital audio input
supported bit depth and sample rates: up to 32-bit/96kHz
1 set of balanced stereo XLR inputs
4 stereo RCA audio inputs
phono input for moving magnet (MM) cartridge, also compatible with high-output moving coil (MC) cartridges
IR input for connecting an IR receiver
Outputs:
1 pair custom McIntosh gold-plated binding-post speaker connectors
full-size headphone output (20-600 ohms recommended impedance)
RCA preamp out/power amp input jacks
Other Info and Specs:
asynchronous USB technology for reduced timing jitter and better sound
does not offer bass, treble, or tone controls
Power Control output provides convenient turn-on/off of McIntosh source components
four Data Ports provide remote control of amplifier-connected McIntosh source components
RS232-C connector for connection to a computer or other control device
remote
17-1/2"W x 6"H x 22"D
weight: 38 lbs.
אמיר
050-3040200
Inputs:
Outputs:
remote
weight: 38 lbs.
