Amirbrand
לפרטים:
אמיר
050-3040200
Technical Specifications
Continuous power output (20Hz—20kHz at 0.5% THD), per channel
Both channels, 8Ω, 20Hz—20kHz: 120W
Single channel, 4Ω, at 1kHz: 240W
Harmonic distortion, 80% power, 8Ω at 1kHz: 0.001%
Inputs
Phono (MM) cartridge:
Input sensitivity at 1kHz: 5mV
Input impedance: 47kΩ + 270pF
Frequency response (ref. RIAA curve): 20Hz—20kHz ± 1dB
Signal/Noise ratio (Awtd) 50W, ref. 5mV input: 80dB
Overload margin, ref. 5mV at 1kHz: 20dB
Preamplifier output
Nominal output level: 900mV
Output impedance: 240Ω
Inputs:
Nominal sensitivity: 1V
Input impedance: 10kΩ
Maximum input: 4.6V
Frequency response: 20Hz—20kHz ± 0.2dB
Signal/noise ratio (Awtd) 50W, ref. 1V input: 105dB
Headphone output
Maximum output level into 600Ω: 4V
Output impedance: 1Ω
Load range: 16Ω—2kΩ
Accessory power output
2.1mm DC connector: 6V, 1A
General
Mains voltage: 110–120V~ or 220–240V~
Power consumption (maximum): 1kW
Dimensions W x D x H (including feet): 433 x 425 x 100mm
Weight (net): 11.5kg
Weight (packed): 13.2kg
Supplied accessories
Mains lead
CR902 remote control
2 x AAA batteries
Accessory power cable
אמיר
050-3040200
Inputs
Preamplifier output
Inputs:
Maximum input: 4.6V
Headphone output
Load range: 16Ω—2kΩ
General
Mains lead
2 x AAA batteries
