מגבר משולב HEGEL H80 DAC זכה במגבר השנה במגזין Lydogbilde
soundquest
מגבר משולב HEGEL H80+ HIGH END DAC זכה במגבר השנה במגזין Lydogbilde
עכשיו זה רשמי
החדר של HEGEL זכה בתואר BEST SOUND בתערוכת Rocky Mountain Audio Fest 2013 במגזין SoundStage
בתערוכת Rocky Mountain Audio Fest שהתקיימה בדנוור ארה"ב הודגמו בחדר של HEGEL
מגבר משולב H80 HEGELמחובר לממיר HEGEL HD-25רמקולים של MAGICO מדגם S1 וכבילה של חברת Nordost
המערכת זכתה לאהדה רבה ונחשבה בידי רבים כמערכת בעלת הסאונד הטוב ביותר בתערוכה!
לינק לזכייה
When I first walked into Hegel Music Systems’ room, I thought their system was complex, but after a couple minutes I realized that they were statically showcasing a number of their components there, but making sound was a simple stereo comprised of their new H80 integrated amplifier-DAC ($2000) and a pair of Magico S1 speakers ($12,600 per pair). Feeding music files to the H80 was a MacBook Air laptop, and once again Nordost cables were chaining the components together.
The thing about the Hegel-Magico combo wasn’t only the simplicity, but the sound. By no small margin, this was the best-sounding stereo I’ve heard so far, even among the many separates-based ones I saw kicking around, which brings me to an interesting, final point: this simpler-system approach doesn’t have to be about creating something that’s more convenient and attractive in a room; done right, the result might be something that actually sounds better as well!
Doug Schneider
Publisher, The SoundStage! Network
Link
בנוסף נכתב ב- Stereophile
Low Noise, Superb sound from HEGEL
By John Atkinson • Posted: Oct 21, 2013
Bent Holter, founder of and designer for the Norwegian company Hegel, explained that his circuits are based on work he had done designing ultra–low-noise preamplifiers for the European CERN laboratory. Hegel's new H80 D/A integrated amplifier ($2000) replaces the H70, which was introduced in 2010, and uses the low-noise preamp circuit from the $5500 H300 amplifier and Hegel's patented feed-forward "Sound Engine" amplifier topology. It has two single-ended analog inputs, one balanced analog input, and five digital inputs, including USB. Though this doesn't operate in the usual asynchronous mode, it uses a proprietary reclocking topology said to eliminate jitter. The H80 offers 75Wpc into 8 ohms compared with the H70's 70W.
Hegel's HD25 DAC ($2500) uses a 32-bit AKM chip and offers even lower noise than the DAC used in the H80. In a series of level-matched comparisons between the H70 and H80 and the HD25, the H80 offers improved clarity and better low-frequency extension and control compared with the H70. While the best sound in the system, which featured Magico S1 speakers ($12,500/pair) and Nordost Red Dawn cables, with digital data sourced from a MacBook Air, was with the HD25's analog outputs feeding the H80, the H80 fed digital data sounded superb for $2000.
Perhaps the most exciting new product Hegel was showing at RMAF was the Super, a $399 portable USB D/A headphone amplifier. Machined from a single block of aluminum, this has a digital-domain volume control, but the circuit's noisefloor is so low that it is claimed to preserved resolution at lower volumes. The Super also has an extremely low output impedance so should be able to drive even the most demanding headphones with ease.
Link
הפלא החדש מ- HEGEL
HEGEL H80 - High End Integrated Amplifier + High-End DAC
ה- HEGEL H80 הינו HIGH CURRENT 75W לצד ב-8 אום משולב עם DAC ממודול של הממיר המפורסם HEGEL HD11 עם טכנולוגיות ה- Re-Clocking.
ה- HEGEL H80 הינו גרסה מוקטנת של ה- HEGEL H300 ומבוסס על פיתוחים שנכללים במוצרים היותר איזוטריים של HEGEL.
בזכות טכנולוגית ה- SoundEngine (המוגנת כפטנט) המגבר הינו בעל גוון צליל עשיר, דינאמי וטבעי שלא מקובל במגברים טרנזיסטורים רגילים.
*טכנולוגיית ה - SoundEngine באה לידי שימוש במוצרי HEGEL בלבד.
המגבר כולל 3 כניסות אנלוגיות ו- 5 כניסות דיגיטליות.
המגבר הינו Fully Balanced
Damping factor More than 1000
לקטלוג HEGEL H80
עכשיו בתצוגה
מגבר משולב HEGEL H80מחובר לרמקולים SPENDOR D7וכבילה של VOVOX
_________________
לפרטים נוספים ניתן ליצור קשר ל - 054-2828400
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות.
www.soundquest.co.il
סאונדקווסט בפייסבוק
    KB 19.9 · צפיות: 393
    KB 66.9 · צפיות: 444
    KB 49.2 · צפיות: 466
    KB 20.6 · צפיות: 442
    KB 20.4 · צפיות: 452
    KB 37.9 · צפיות: 456
    KB 146.1 · צפיות: 474
    KB 153.4 · צפיות: 440
