סאב מדהים !!! כולל חיבור של Hi-Level הניזון ישירות מהמגבר הראשי ליצירת בס אמיתי ונאמן למקור.
9000 ש"ח
ניר - 0547693833
True 200W (continuous] discrete direct-coupled MOSFET amplifier Forward-firing 250mm (10"), long-throw, heavy-duty driver with 7.6 kg magnet and 4 layer edge-wound voice-coil Refined ABC® infinitely variable crossover adjustment from 26 to 106 Hz Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase) Audiophile grade toroidal transformer Gas-tight Neutrik high level connection for long-term consistency of sound quality High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level) Totally discrete input circuitry for high and low level inputs Separate volume controls for high and low-level input adjustment Simultaneous connection of high and low level sources Set-Safe® audibly transparent driver protection 4x ultra-rugged output devices Double-sided glass-fibre board with plated-through holes IEC power input socket - non-captive lead for installation flexibility Heavy duty grille Machined nylon feet Hand-built in Great Britain
9000 ש"ח
ניר - 0547693833
