חזרו לתצוגה ונשמעים מדהים!!! SPENDOR A6R
soundquest
%D7%93%D7%93-jpg.30463
%D7%A2%D7%9B%D7%A2-jpg.30465
%D7%9C%D7%97%D7%9C-jpg.30464
SPENDOR A6R זכו כרמקולי הסטריאו הטובים ביותר לשנת 2015 במגזין האנגלי ?WHAT HI FI שנה שנייה ברציפות!
Spendor A6R scoops this major award. "An outstanding pair of speakers that deliver detail and dynamic punch. Audition them, and you'll hear where every penny of your money is going
"They put in a superb performance across the frequency range, showcasing a surprisingly deep and punchy low end alongside an expressive midrange and a detailed, refined treble. Each feels like a well-judged part of a whole, slotting together perfectly to produce a well-balanced, coherent system."
"Detail is second to none too, and there is layer upon layer of subtlety and fine detail to grasp onto. Notes have depth and dimension, nuances are picked up in all their glory and vocals are conveyed with all the reality and emotion with which they were recorded."
Test Verdict - "An outstanding pair of speakers..."
Group Test Verdict - Winner
לינק לביקורת
בנוסף:
Hi-Fi Choice magazineFebruary 2014
"Bass is excellent and I can vouch that Spendor’s special port design works very well. Even at high levels, there is no huffing, puffing or chuffing, and the low frequencies remain tight and supple."
"The midrange performance of the A6R is lovely. It does that very special trick of being incisive and detailed without sounding like a speaker that’s trying to be incisive and detailed! Rather it has a smooth, gentle, delicate sort of character that seems to dissolve away and let you focus on the mix; there’s no honking or squawking from the cone, no sense that you’re listening to something artificial."
Its sheer competence across the board means it’s really hard, if not impossible, to beat. You just can’t help really liking it, no matter what you’re currently used to and how expensive it is. As such, it comes heartily recommended."
לינק לביקורת
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות
ירמיהו 43 תל אביב > 03-6721808
www.soundquest.co.il
סאונדקווסט בפייסבוק
    KB 14.4 · צפיות: 513
    KB 48.7 · צפיות: 508
    KB 28.1 · צפיות: 517
    KB 56.1 · צפיות: 922
    KB 85.2 · צפיות: 893
    KB 89.5 · צפיות: 939
איתי ו.
עם איזו הגברה ומקור אתה מדגים אותם?
soundquest
היי איתי,
כרגע מנגנים דרך סטרימר של AVM 5.2 דרך היציאה הדיגיטלית לתוך מגבר משולב HEGEL H160 DAC וכבילה של VOVOX.
מוזמנים לתאם הדגמה!
