זוג רמקולים רצפתיים FOCAL Sopra No.2 במחיר מטורף!!!
Amirbrand
JMlab Sopra N°2 זוג רמקולים רצפתיים ניתן להתרשם מהרמקולים בחנות !
Sopra n°2 clearly inaugurates a new era for the “Premium High End” by taking into account new performance criteria. Compact, modern, a pure design, character... all these are essential factors to ensure perfect integration into your interior.
Equipped with best midrange drivers ever developed by Focal, with the NIC and TMD technologies, Sopra n°2 pushes back the limits of sound reproduction in terms of transparency in a very compact enclosure. Indeed, unlike Utopia, which is extravagant by essence and where size is by no means a constraint, Sopra aims for maximal compactness to ensure easy integration into reasonably sized rooms.
The two 18cm woofers for the bass register equipped with natural inductance magnetic circuits benefit from a substantial volume thanks to the tweeter’s IHL, allowing us to take full advantage of the cabinet’s capacity. Indeed, unlike Utopia , which is extravagant by essence and where size is by no means a constraint, Sopra aims for maximal compactness to ensure easy integration into reasonably sized rooms.
What’s more, the cabinet’s Gamma Structure with a 69mm front panel provides remarkable inertia considering such a size. Weighing 55kg, Sopra n°2 is by no means envious of its larger competitors... Thus weight and compactness are well balanced to provide impressive density and articulation.
This remarkable control of the bass makes Sopra n°2 even easier to integrate. It is perfectly at ease in rooms measuring up to 30m2, and is even ideal for larger rooms measuring up to 70m2.Key Features
  • New midrange driver with TMD suspension (Tuned Mass Damper)
    and "NIC" magnetic circuit (Neutral Inductance Circuit)
  • New "IHL" Beryllium tweeter (Infinite Horn Loading)
  • Drivers developed and manufactured by Focal in France
  • Lacquered standard finishes (face + side panels): Carrara White, Imperial Red, Electric Orange
  • Standard wood veneer finish: Graphite Black (face), Dogato Walnut (side panels)
Specification
Type Three-way Bass-reflex floor standing loudspeaker
Drivers Two 18cm "W" woofer
16.5cm "W" midrange with "TMD" suspension, "NIC" motor
25mm "IHL" Berylium inverted dome tweeter
Frequency response (+/- 3dB) 34Hz - 40kHz
Low frequency point - 6dB 28Hz
Sensitivity (2.83V / 1m) 91dB
Nom. impedance 8 Ohms
Minimum impedance 3.1 Ohms
Recommended amplifier power 40 - 300W
Crossover frequency 250Hz / 2 200Hz
Dimensions (HxLxP) 1 190x358x540mm
Net weight 55kg
לפרטים, ניתן לחייג ל:
050-3040200 אמיר
