Bg-Sound
BG sound מציעה מגבר סטריאו איכותי מבית Naim Audio
דגם: SuperUnity.
מדובר במגבר All In One
הכולל: הגברה - סטרימר - רדיו - בלוטוס ועוד.
שמור כחדש וכולל שלט רחוק.
ניתן להתרשם מהמגבר וממוצרי סטריאו נוספים בסניף רמת גן - חניה פרטית לרשות הלקוחות.
http://bg-sound.co.il/he/יד-שנייה/
ביקורות רבות ברשת.
מחיר חדש: 23,000 ש"ח
צרו קשר למחיר ופרטים נוספים.
דגם: SuperUnity.
ביקורות רבות ברשת.
SuperUniti genuinely can do it all. Take a deep breath because listing its talents takes a while. SuperUniti is an integrated wireless UPnP™ network stream player, USB audio player, iPod and iPhone dock, internet radio, DAB radio, FM radio, ten input digital and analogue preamplifier, digital to analogue converter, and stereo 80 Watt power amplifier. And just so that you don't lose track of time while listening - easily done - it has an alarm clock too. Out of breath?
SuperUniti might well contain all the audio versatility you'll ever need, but audio versatility is nothing without musical ability, and that's where four decades of Naim audio expertise comes in. Not only does SuperUniti do everything, it does it all with brilliant clarity and heart-stopping emotion. Every musical source, from internet radio via analogue inputs through to digital streams, is played with genuine musical quality. Every drop of music is squeezed from every stream of data - whatever its provenance.
AUDIO INPUTS
Analogue Inputs 1 x 5-pin DIN, 2 x RCA pair, 1 x 3.5mm front panel jack
Input Sensitivity 170mV
Overload Margin 34dB
Input Impedance 47k
Digital Inputs 6 x S/PDIF (1 x coaxial BNC, 1 x coaxial RCA, 3 x optical TOSlink, 1 x 3.5mm front panel mini-TOSlink)
Sample rates maximum 192kHz (coaxial) 96kHz (optical)
Bit depths maximum 24 bits
UPnP input Ethernet (RJ45) and Wi-Fi
USB/iPod input Front panel USB Type-A
Playlist supported M3U and PLS
FM and DAB input F-type
Tuning Range FM 87.5 - 108MHz, DAB Band III and L Band
iRadio input Ethernet (RJ45) and Wi-Fi
Service provider Vtuner 5*
Minimum Load Impedance 10kΩ
AUDIO OUTPUTS
Output power 80Wpc into 8Ω, 120Wpc into 4Ω(0.1% THD both channel driven)
Frequency Response 3.5Hz to 34kHz
Signal To Noise Ratio (S/N ratio) 85dB
Crosstalk 80dB
Phase Response Linear Phase, absolute phase correct
Headphone outputs Stereo (front panel 3.5mm jack)
Output power 105mW into 16Ω
Other analogue outputs Preamp output (4-pin DIN), Subwoofer output (RCA pair)
Digital Outputs (type) S/PDIF (coaxial BNC 75Ω)
SPEAKER OUTPUTS
Speaker Outputs Stereo (4mm)
CONNECTIVITY
Infra Red Front panel
Remote Input RC5 input (3.5mm rear panel jack)
RS232 Updates only (rear panel USB mini-B)
Remote Output RC5 input (3.5mm rear panel jack)
FORMATS
Audio Formats Supported WAV and AIFF (up to 32bit/192kHz) FLAC (up to 24bit/192kHz) ALAC (up to 24bit/96kHz) WMA (up to 16bit/48kHz) must be WMA 9.2 Ogg Vorbis (up to 16bit/48kHz) MP3 and M4a (up to 320kbit/s)
Audio Formats Supported WMA, MP3, MMS
USER CONTROL INTERFACES
Front Panel Volume control, logo mute and buttons
AMX and Creston Yes
Remote Uniti family remote
iPod/iPhone/iPad n-Stream
POWER
Mains Supply 100V, 115V or 230V, 50/60Hz
Quiescent consumption 35W
Maximum consumption 400VA
Supplied accessories Wi-fi antenna, Uniti family remote handset, batteries, BNC to RCA adaptor,F-type to PAL adaptor, mains lead, speaker plugs
PRODUCT CERTIFICATIONS & LICENSES
Certifications Apple (Made for iPhone), vTuner Premium
Licenses MP3, AAC, DAB
PHYSICAL
Dimensions 87 x 432 x 314mm
Weight 12.8kg
Shipping Dimensions 240 x 590 x 500mm
Shipping Weight 15.5kg
קבצים מצורפים:SuperUniti might well contain all the audio versatility you'll ever need, but audio versatility is nothing without musical ability, and that's where four decades of Naim audio expertise comes in. Not only does SuperUniti do everything, it does it all with brilliant clarity and heart-stopping emotion. Every musical source, from internet radio via analogue inputs through to digital streams, is played with genuine musical quality. Every drop of music is squeezed from every stream of data - whatever its provenance.
AUDIO INPUTS
Input Impedance 47k
AUDIO OUTPUTS
Crosstalk 80dB
SPEAKER OUTPUTS
CONNECTIVITY
FORMATS
AMX and Creston Yes
POWER
PHYSICAL
Weight 12.8kg
