ביקורת חדשה (מאי 2018) להארקה פסיבית NORDOST QKORE במגזין האודיו היוקרתי the absolute sound
soundquest
לינק לביקורת
file.php
file.php
פרס למוצר המשלים הטוב ביותר הוענק ל NORDOST QKORE במגזין האנגלי HiFi+
file.php
The popularity, efficacy, and use of ground units appears to be a comparatively recent phenomenon, but in fact dates back to the earliest days of good audio. It was not uncommon for audio enthusiasts to run an additional star-earthing network, connecting devices to a common ground independent to the one used in the mains itself. The Nordost QKORE grounding units take and extend that notion to its logical limits. QKORE is built around three products, a QKORE1 with a single binding post designed to connect to the power before the electronics (ideally connecting to something like a Qbase), QKORE3 that includes three binding posts to connect to the electronics (plugging into a spare RCA socket), and QKORE6 that combines the QKORE1 and QKORE3, adding a supplementary set of mono ground connectors, for an all-in-one package or for users of mono power amps.
In our test, Hi-Fi+ Editor Alan Sircom was impressed. “The main effect was in the bass,” He said, “which sounded significantly tighter, deeper, and more authoritative. More significantly, QKORE was like a quick lesson in ‘time coherence’.” He concluded that, “the benefits are immediate, easy to hear, and extremely consistent from system to system, even in systems that may never use another Nordost product.” It’s time to feel grounded!
See: hifiplus.com/articles/exclusive-munich-preview-nordost-qkore-grounding-system/
לינק לפרס
*סקירה נוספת ל NORDOST QKORE במגזין Son & Image Magazine
Every home has a main electrical safety ground, as required by all electrical building codes. Safety grounding is achieved by connecting the metallic casings of all electrical appliances to a ground conductor that leads to an earth ground. In the case of an audio system, components are connected to the safety ground via the ground pin of their three-pin power cords. While this main ground network ensures safety, it also …
.pdf]לינק לסקירה
*עוד סקירה מעולה ל NORDOST QKORE במגזין Audiotechnique
לינק לסקירה
*סקירה נוספת ל NORDOST QKORE במגזין The Audio Beat
Even with the breakneck pace of advancement in the consumer-electronics industry, high-end audio has remained rather staid, the not too-recent rise of high-resolution file playback notwithstanding. Playing records, the most ancient of recording media, is as hot now as it has ever been since the advent of digital. The majority of speakers still . . . .
לינק לסקירה
*הביקורת של Alan Sircom ל NORDOST QKORE
ometimes we as journalists are privy to way prior to their launch. Such is the case with Nordost’s QKORE trio of ground units. I was told about these at CES this year, but was so sworn to secrecy that they appeared as ‘Nordost stuff’ and later ‘Nordost Q Project’ on our internal planning documents. Even Nordost’s distributors will only . . . .
לינק לביקורת
לינק למידע נוסף על NORDOST QKORE באתר היצרן
file.php
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות
ירמיהו 43 תל אביב > 03-6721808
www.soundquest.co.il
סאונדקווסט בפייסבוק
