ביקורת וחמישה כוכבים***** לרמקולים SPENDOR A6R במגזין Hi fi Choice
soundquest
"Bass is excellent and I can vouch that Spendor’s special port design works very well. Even at high levels, there is no huffing, puffing or chuffing, and the low frequencies remain tight and supple.""The midrange performance of the A6R is lovely. It does that very special trick of being incisive and detailed without sounding like a speaker that’s trying to be incisive and detailed! Rather it has a smooth, gentle, delicate sort of character that seems to dissolve away and let you focus on the mix; there’s no honking or squawking from the cone, no sense that you’re listening to something artificial."Its sheer competence across the board means it’s really hard, if not impossible, to beat. You just can’t help really liking it, no matter what you’re currently used to and how expensive it is. As such, it comes heartily recommended."
לינק לביקורת
בנוסף,
ביקורת חמישה כוכבים וזכייה השוואתית לרמקולים של ספנדור מדגם A6R
GROUP TEST WINNER A6R What Hi-Fi February 2014
*****5 "An outstanding pair of speaker."
"They put in a superb performance across the frequency range, showcasing a surprisingly deep and punchy low end alongside an expressive midrange and a detailed, refined treble. Each feels like a well-judged part of a whole, slotting together perfectly to produce a well-balanced, coherent system."
"Detail is second to none too, and there is layer upon layer of subtlety and fine detail to grasp onto. Notes have depth and dimension, nuances are picked up in all their glory and vocals are conveyed with all the reality and emotion with which they were recorded."
Test Verdict - "An outstanding pair of speakers..."
Group Test Verdict - Winner!!!
לינק לביקורת
_________________
סאונדקווסט - יבוא ושיווק מערכות אודיו וידאו יוקרתיות.
http://www.soundquest.co.il/www.soundquest.co.il
סאונדקווסט בפייסבוק
    KB 14.4 · צפיות: 405
    KB 121 · צפיות: 401
    KB 44.1 · צפיות: 462
    KB 19.9 · צפיות: 466
    KB 156.8 · צפיות: 394
    KB 118.5 · צפיות: 438
    KB 121 · צפיות: 439
    KB 47.7 · צפיות: 456
